Meet the reliable, small desktop redesigned to fit perfectly on your desk and with your business.
Packed with power: Work throughout your day quickly and conveniently with the latest Intel processors and up to 8GB2 of high-speed RAM options, delivering power and reliable performance.
Stay connected: Quickly transmit important business data with built-in WiFi or a Gigabit Ethernet connection.
A boost in multitasking: Run multiple apps faster and enjoy sharp, high-quality visuals on everything from Excel spreadsheets to video editing with up to 2GB2 of optional discrete graphics.
Plenty of room: Save and access presentations, documents and media without worry of space limitations with up to a 2TB2 HDD.
Built for desk space: The compact form factor design ensures that you save space without sacrificing features or performance.
Uninterrupted performance: The new ventilation system and ultra-fine filter were created to improve airflow, reduce dust, and help keep your system cool.
Easy expansion: Need more performance? You can upgrade the Vostro Small Desktop as needed with expansion slot options to keep up with your business growth.
Product Description | Dell Vostro 3250 - SFF - Core i5 6400 2.7 GHz - 4 GB - HDD 500 GB | Type | Personal computer - small form factor | Bundled Services | 1 Year Dell Collect and Return Service | Processor | Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB L3 Cache | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC | Storage Controller | SATA | Hard Drive | HDD 500 GB - SATA - 7200 rpm | Optical Storage | DVD-Writer | Card Reader | Yes | Graphics Controller | Intel HD Graphics 530 | Audio Output | 5.1 channel surround | Networking | GigE, Bluetooth, 802.11b/g/n | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Microsoft Office (Trial), McAfee (30 days trial) | Colour | Black | Dimensions (WxDxH) | 29.3 cm x 9.26 cm x 29 cm | Weight | 3.17 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6400 |
Clock Speed | 2.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | L3 Cache - 6 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3L SDRAM - non-ECC |
Effective Memory Speed | 1600 MHz |
Form Factor | DIMM 240-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer |
Card Reader | |
Type | Card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 |
Video Interfaces | VGA, HDMI |
Audio Output | |
Sound Output Mode | 5.1 channel surround |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse (on selected markets only), keyboard (on selected markets only) |
Mouse | |
Technology | Optical |
Networking | |
Wireless LAN Supported | Yes |
Wireless NIC | Dell Wireless 1707 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x internal 2 x 2.5"/3.5" shared |
Slots | 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 1 (free) x PCIe x1 - full-height , 1 (total) / 0 (free) x M.2 Card |
Interfaces | 4 x USB 2.0 , 2 x USB 3.0 (2 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out/headphones , 1 x audio line-in/microphone , 1 x audio line-in , 1 x VGA , 1 x HDMI |
Miscellaneous | |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Operating System / Software | |
Software | Microsoft Office (Trial), McAfee (30 days trial) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 29.3 cm |
Depth | 9.26 cm |
Height | 29 cm |
Weight | 3.17 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
