With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity.
Made with premium-quality materials, the UZ2315H has BFR/PVC-free laminates in its circuit boards and has arsenic-free glass and a mercury-free LED panel. The chassis is made of more than 25 percent post-consumer recycled plastics.
Product Description | Dell UltraSharp UZ2315H - LED monitor - Full HD (1080p) - 23" - with 3-years Premium Panel Exchange service | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class A | Energy Consumption per Year | 28 kWh | Features | 2.0 megapixel camera, 2 microphones, USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.265 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 83% (CIE 1976) | Input Connectors | 2xHDMI, VGA, 2xMHL, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.38 cm x 18 cm x 37.69 cm | Weight | 5.33 kg | Localisation | United Kingdom | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VESA EDID, DDC/CI, RoHS | Manufacturer Warranty | 3-year warranty | Bundled with | 3-years Premium Panel Exchange service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | 2.0 megapixel camera, 2 microphones, USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 9300K, 5000K, 6500K, 7500K, 10000K, 5700K |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, saturation, gamma correction, input select, colour temperature, phase, clock, hue, aspect control |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features | Ultra wide viewing angle, PowerNap, stand lock, Energy Gauge, Energy Saver, Transition Minimised Differential Signaling (TMDS) technology |
Colour | Black |
Dimensions (WxDxH) | 56.38 cm x 18 cm x 37.69 cm - with stand |
Weight | 5.33 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | VGA , 2 x MHL / HDMI , DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphone/microphone combo jack |
Mechanical | |
Tilt Angle | -5.5/+22 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 125 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), LED indicator, integrated cable management |
Included Accessories | Stand |
Cables Included | 1 x power adapter , 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 1.2 Watt |
Power Consumption Sleep | 1.2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 56.38 cm - depth: 4.46 cm - height: 36.1 cm - weight: 3.5 kg , With stand - width: 56.38 cm - depth: 18 cm - height: 37.69 cm - weight: 5.33 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
