Dell UltraSharp U2717D 27" 2560x1440 8ms HDMI LED LCD Monitor
Key features
  • Seamless and precise with thin borders on all sides of the screen, creating an almost seamless multi-monitor view
  • Designed with purpose due to multiple customization possibilities allowing you to adjust your monitor to best fit the way you work
  • Unmatched reliability
Product codes
chevron icon
chevron icon
The Dell UltraSharp 27 InfinityEdge monitor U2717D takes your view to the edge with less borders.
chevron icon
Product Description Dell UltraSharp U2717D - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (typical), 6 ms (fast)
Colour Support 16.7 million colours
Colour Gamut 99% sRGB
Input Connectors HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 61.13 cm x 20.03 cm x 41.02 cm
Weight 7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VESA EDID, DDC/CI, RoHS
Bundled Services 3 years Advanced Exchange Service
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
