Bring your work to life in vivid color detail, sharp QHD resolution and extensive connectivity for outstanding usability. Superior screen clarity meets complete color precision for a brilliant viewing experience.
Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel.
Product Description | Dell UltraSharp U2515H - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class B | Energy Consumption per Year | 41 kWh | Power Consumption (On mode) | 28 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.216 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 2000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey), 19 ms (On/Off) | Colour Support | 16.8 million colours | Colour Gamut | 76% (CIE 1931), 91% (CIE 1976), 99% sRGB | Input Connectors | 2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.9 cm x 20.5 cm x 39.8 cm | Weight | 6.5 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VESA EDID, DDC/CI, NFPA 99 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 86 Hz |
Horizontal Refresh Rate | 30 - 113 kHz |
Video Bandwidth | 241.5 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 9300K, 5000K, 6500K, 7500K, 10000K, 5700K |
Controls & Adjustments | Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features | LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, Factory Calibration, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, backlight dimming control, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 56.9 cm x 20.5 cm x 39.8 cm - with stand |
Weight | 6.5 kg |
Connectivity | |
Interfaces | USB 3.0 upstream , 5 x USB 3.0 downstream , DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , DisplayPort output (MST) , Audio line-out |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 115 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots |
Included Accessories | Stand, cable management cover |
Cables Included | 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 87 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.9 cm - depth: 20.5 cm - height: 39.8 cm - weight: 6.5 kg , Without stand - width: 56.9 cm - depth: 4.64 cm - height: 33.87 cm - weight: 4.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
