Flexible and user-friendly for work, school or fun. The Dell 21.5" touch monitor offers you 10-point touch capability with outstanding clarity and usability in a clean, efficient design.
Product Description | Dell S2240T - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class A | Features | Touch-screen, USB 2.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 8000000:1 (dynamic) | Response Time | 12 ms (overdrive) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 84% (CIE 1976) | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 52.25 cm x 20.57 cm x 37.08 cm | Weight | 5.1 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, DDC/CI | Manufacturer Warranty | 3-year warranty | Bundled with | 3-Years Advance Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 2.0 hub |
Panel Type | VA |
Brightness w/touchscreen | 280 cd/m² |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control |
OSD Languages | Chinese (simplified), English, German, French, Spanish, Japanese |
Features | LED edgelight system, Dynamic Dimming, Energy Gauge, Energy Saver, glove touch mode |
Colour | Black |
Dimensions (WxDxH) | 52.25 cm x 20.57 cm x 37.08 cm - with stand |
Weight | 5.1 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Movement Resolution | 25 ppi |
Connectivity | |
Interfaces | VGA (HD-15) , HDMI , DVI-D , USB 2.0 upstream , Audio line-out |
Mechanical | |
Tilt Angle | +10/+60 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, VESA interface support |
Included Accessories | Stand, cleaning cloth, touch fastener strap |
Cables Included | 1 x HDMI cable , 1 x USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 52.25 cm - depth: 20.57 cm - height: 37.08 cm - weight: 5.1 kg , Without stand - width: 52.25 cm - depth: 4.12 cm - height: 31.89 cm - weight: 3.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
