With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
Product Description | Dell S2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class A | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 18.5 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.8 million colours | Colour Gamut | 72% (CIE 1931), 82% (CIE 1976) | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 48.8 cm x 17.99 cm x 38.57 cm | Weight | 3.14 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play | Manufacturer Warranty | 3-year warranty | Bundled with | 3-Years Advance Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control |
Features | LED edgelight system |
Colour | Black |
Dimensions (WxDxH) | 48.8 cm x 17.99 cm x 38.57 cm - with stand |
Weight | 3.14 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | HDMI , VGA , Audio line-in , Audio line-out |
Mechanical | |
Tilt Angle | -5/+21 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x HDMI cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 48.8 cm - depth: 17.99 cm - height: 38.57 cm - weight: 3.14 kg , Without stand - width: 48.8 cm - depth: 5.42 cm - height: 29.31 cm - weight: 2.6 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
