Power up your system for business trips and vacations with this 6-Cell Battery from Dell™. With a capacity of 60 WHr this battery lets you work seamlessly when you are on the move. The integrated battery charge gauge lets you check the charge status of an installed or uninstalled battery at any time. This product has been tested and validated on Dell systems to ensure it will work with your computer. It is supported by Dell Technical Support when used with a Dell system.
Highlights:
Product Description | Dell Primary Battery - laptop battery - 60 Wh | Device Type | Laptop battery | Battery | 6-cell - 60 Wh | Designed For | Latitude E5420, E5420m, E5430, E5520, E5520m, E5530, E6420, E6420 ATG, E6430, E6430 ATG, E6440, E6520, E6530, E6540 |
General | |
Battery | |
Technology | 6-cell |
Capacity | 60 Wh |
Compatibility Information | |
Designed For | Dell Latitude E5420, E5420m, E5430, E5520, E5520m, E5530, E6420, E6420 ATG, E6430, E6430 ATG, E6440, E6520, E6530, E6540 |
