BT.com
Wishlist
Dell P2317H 23" 1920x1080 6ms LED HDMI VGA Monitor
Delivery
Standard Due date unavailable
More productive than ever. This Dell monitor brings an amazing level of productivity to the work place without sacrificing comfort and convenience.
Dell P2317H - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
53.2 cm x 18 cm x 35.71 cm
5.59 kg
Environmental Standards
ENERGY STAR Qualified
RoHS, CECP, CEL, TCO Displays, TUV Rheinland
Display Type
Energy Class
Class A+
22 kWh
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, ultra wide viewing angle, 82% (CIE 1976) colour gamut, PowerNap, stand lock, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
53.2 cm x 18 cm x 35.71 cm - with stand
5.59 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 18 cm - height: 35.71 cm - weight: 5.59 kg , Without stand - width: 53.2 cm - depth: 5.03 cm - height: 31.59 cm - weight: 3.06 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
Scroll to top
