Use both hands and the responsive 10-point touch capability to quickly and smoothly navigate across the edge-to-edge glass of your P2314T. The ergonomic stand offers optimal application and game control, as well as viewing comfort.
VGA, USB, DP and HDMI ports plus MHL connectivity allows direct display of smartphone/tablet content on the touch monitor while charging your mobile device at the same time.
Product Description | Dell P2314T - LED monitor - Full HD (1080p) - 23" - with 3-years Premium Panel Exchange service | Device Type | LED-backlit LCD monitor - 23" - touchscreen | Features | Touch-screen, USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.265 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.8 million colours | Colour Gamut | 72% (CIE 1931), 83% (CIE 1976) | Input Connectors | 2xHDMI, VGA, 2xMHL, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.99 cm x 8.09 cm x 41.27 cm | Weight | 6.28 kg | Localisation | United Kingdom | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VESA EDID, DDC/CI | Manufacturer Warranty | 3-year warranty | Bundled with | 3-years Premium Panel Exchange service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features | Ultra wide viewing angle, LED edgelight system, PowerNap, edge-to-edge glass, 10-point multi-touch, BFR/PVC-free, Energy Gauge, glove touch mode, Transition Minimised Differential Signaling (TMDS) technology |
Colour | Black |
Dimensions (WxDxH) | 56.99 cm x 8.09 cm x 41.27 cm - with stand |
Weight | 6.28 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | 2 x MHL / HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , Audio line-out |
Mechanical | |
Tilt Angle | +10/+60 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, VESA interface support |
Included Accessories | Stand, cleaning cloth, touch fastener strap |
Cables Included | 1 x HDMI cable , 1 x SuperSpeed USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 26 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.99 cm - depth: 8.09 cm - height: 41.27 cm - weight: 6.28 kg , Without stand - width: 56.99 cm - depth: 4.22 cm - height: 34.81 cm - weight: 4.82 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
