We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Maximize productivity on the 21.5-inch FHD monitor with a three-sided ultrathin bezel, powerful connectivity, ComfortView Plus and an eco-friendly design.
Product Description | Dell P2223HC - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class D | Power Consumption (On mode) | 12 W | Features | USB 3.2 Gen 1/USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.24795 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 1000:1 (dynamic) | Response Time | 14 ms (normal), 5 ms (fast) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 48.726 cm x 17.957 cm x 48.199 cm | Weight | 4.97 kg | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free | Bundled Services | 3-Years Advanced Exchange Service and Premium Panel Guarantee |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Built-in Devices | USB 3.2 Gen 1/USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 102.46 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED edgelight backlight |
Features | Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus |
Colour | Black |
Dimensions (WxDxH) | 48.726 cm x 17.957 cm x 48.199 cm - with stand |
Weight | 4.97 kg |
Connectivity | |
Interfaces | HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Included Accessories | Cable tie |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12 kWh/1000h |
Power Consumption (Max) | 118 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 48.726 cm - depth: 17.957 cm - height: 48.199 cm - weight: 4.97 kg , Without stand - weight: 3.03 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.63 kg |
Sustainability Information | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
