The ultimate 14.0" productivity tool, designed for better security, manageability and reliability. Built with a versatile design and essential business features.
Log in with ease: Activate Windows Hello via optional infrared camera to facilitate facial recognition for easy and secure access.
Trusted authentication: The Latitude 5480 offers multiple security options to meet your diverse security needs. Features include essential multi-factor authentication hardware such as touch fingerprint reader, contacted FIPS 201 Smart Card Reader and Contactless Smart Card Reader NFC with Control Vault 2 Fips 140-2 Level 3 Certification to prevent unauthorized access.
Protection from attacks: Dell ControlVault provides a more secure alternative for storing and processing passwords, biometric templates and security codes.
Manage with ease: Through Dell unique vPro extensions, you can remotely manage a fleet of devices, including diagnostics whether they are powered on or off.
The power to perform: Leverage scalable performance using Intel's latest 7th Gen Core i Dual (U) or Quad Core (H) processors, NVIDIA graphics and a range of storage options from HDD to M.2 PCIe NVMe.
Designed with purpose: Work confidently on a laptop equipped with all-day battery life and if needed, bring your Dell Power Companion for an extended day.
Focus on work, not your notebook: Tested against 15 MIL STD 810G benchmarks, the incredibly durable systems make sure your work stays safe wherever you go.
Only Dell offers industry-leading encryption, authentication including optional touch fingerprint reader and leading-edge malware prevention from a single source right out of the box. Plus, with Dell Data Protection , Protected Workspace, your data is safe across all endpoints, including external media, self-encrypting drives and in public cloud storage.
The world's most manageable laptop is built to allow flexible and automated BIOS and system configurations through Dell Client Command Suite free tools. Dell makes it easy to deploy, monitor and update your Latitude fleet.
Features a durable, built-to-last chassis that has undergone extensive military-grade MIL-STD 810G testing that ensures your system can withstand real-world conditions.
Product Description | Dell Latitude 5480 - 14" - Intel Core i5 - 7200U - 8 GB RAM - 128 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 128 GB SSD | Display | 14" 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM) Security Chip, smart card reader | Colour | Black | Dimensions (WxDxH) | 33.34 cm x 22.89 cm x 2.245 cm | Weight | 1.6 kg | Pricing Type | Build To Stock (BTS) | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Display | |
Type | 14" |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 220 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 1280 x 720 |
Resolution | 0.92 Megapixel |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Audio Features | Output: MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Dell Wireless 1820 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.34 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.0 , USB 3.0 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , LAN , HDMI , VGA |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.6 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
