We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
Product Description | Dell E1715S - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" | Energy Class | Class D | Power Consumption (On mode) | 9 W | Panel Type | TN | Native Resolution | 1280 x 1024 at 60 Hz | Pixel Pitch | 0.264 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (black-to-white) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 85% (CIE 1976) | Input Connectors | VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 37.45 cm x 16.55 cm x 38.95 cm | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | Plug and Play, VESA EDID, DDC/CI, RoHS, CECP | Manufacturer Warranty | 3-year warranty | Bundled Services | 3 years Advanced Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 81 kHz |
Video Bandwidth | 135 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue |
OSD Languages | Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese |
Features | LED edgelight system, PowerNap, Image Enhance |
Colour | Black |
Dimensions (WxDxH) | 37.45 cm x 16.55 cm x 38.95 cm - with stand |
Connectivity | |
Interfaces | VGA , DisplayPort |
Mechanical | |
Tilt Angle | -5.5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), LED indicator, VESA interface support |
Included Accessories | Stand, VESA screw cover |
Cables Included | 1 x VGA cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 9 kWh/1000h |
Power Consumption (Typical) | 15 Watt |
Power Consumption (Max) | 14 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
