The mydlink Home Motion Sensor detects motion within its field of view, providing you with a trigger for automating your home. Integrating with D-Link's HNAP protocol, the Motion Sensor connects seamlessly with your Connected Home Hub, guaranteeing compatibility and getting your smart home network up and running right away.
Product Description | mydlink Home Battery Motion Sensor - multipurpose sensor - Z-Wave | Product Type | Multipurpose sensor | Sensor Type | Temperature, ambient light, motion | Connectivity | Wireless - Z-Wave | Frequency Band | 868.4 MHz | Localisation | Europe | Dimensions (WxDxH) | 9.6 cm x 2.8 cm x 2.3 cm |
General | |
Connectivity Technology | Wireless - Z-Wave |
Features | Tamper protection |
Miscellaneous | |
Included Accessories | CR123A lithium battery |
Encryption Algorithm | 128-bit AES |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 9.6 cm |
Depth | 2.8 cm |
Height | 2.3 cm |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 90% (non-condensing) |
