Wishlist updated!
Buffalo 2TB (2 x 1TB) LinkStation Duo RAID 0/1
You have added Buffalo 2TB (2 x 1TB) LinkStation Duo RAID 0/1 to your Wishlist
D-Link DIR-865L AC1750 Simultaneous Dual-Band Broadband Wireless-AC
Key features
  • Fast and reliable home networking
  • Monitor your network with mydlink
  • File sharing right at your fingertips
  • Smooth streaming with Wireless AC
  • Easy to set up and use
Product codes
chevron icon
chevron icon
The new D-Link DIR-865L AC1750 Simultaneous Dual-Band Gigabit Broadband Wireless-AC Router is powered by Broadcom's 5G Wi-Fi IEEE 802.11ac chipset that makes use of the new 802.11ac 5GHz frequency band to deliver speeds up to three times faster than that of Wireless N. Using multiple channels, this D-Link DIR-865L serves wireless speeds of up to 1750 Mbps (1300 Mbps over the 5GHz band plus 450 Mbps over the 2.4GHz band). Additional features such as Gigabit WAN, Gigabit LAN, mydlink support and the D-Link's Quick Router Setup (QRS) which allows customers to quickly configure their router using the QRS Mobile app for iOS or Android devices.
Key Features
Wireless AC1750: Built on the 802.11ac standard the D-Link DIR-865L supports wireless speeds up to 1750Mbps, with 1300Mbps on 802.11ac and 450Mbps in 802.11n using simultaneous dual-band support
SharePort Plus: D-Link SharePort Plus technology makes it easy to share files and multimedia to computers and mobile devices. Using USB, users can connect a multi-function printer (MFP), scanner, or storage device to the router sharing access to these devices to multiple computers.
SharePort Mobile: The SharePort Mobile app for iOS or Android provides access to files and multimedia stored on a USB drive. Music, video, and photos can be streamed or transferred from the connected USB drive to multiple mobile devices.
SharePort Web Access: SharePort Web Access offers a convenient web interface to retrieve files and multimedia shared via SharePort Plus.
DLNA Media Server: The D-Link DIR-865L includes a fully-functional DLNA server for streaming multimedia files including photos, music, and videos to any compatible DLNA media player.
IPv6 Support: Like all new D-Link Routers, the DIR-865L includes support for IPv6, making it forward compatible with the forthcoming changes to the protocol system that powers the Internet.
Parental Controls: Parents concerned about what their children view online can rest easy after configuring parental controls with award-winning web contentment filtering powered by OpenDNS.
The Power of 802.11ac
Backwards compatible with existing wireless devices operating on earlier standards such as 802.11a/b/g/n, 802.11ac provides improved coverage using a beam-forming system that sends a targeted stream of data directly from the D-Link DIR-865L router to the device, thus increasing range and overcoming obstructions for full-home coverage.
Cloud-based Configuration and Management
The D-Link DIR-865L is also a Cloud Router that lets owners have the option to manage and control their 802.11ac wireless networks from the mydlink Cloud Services portal or via an iPhone, iPad or Android device with the mydlink Lite app installed.
The app makes it easy to check the status of family members whenever they arrive home and go online. Parents can also monitor which sites are being visited and block dangerous websites at the touch of a screen. Alert notifications warn users in the event that intrusion attempts are detected and blocked, or whenever important security updates are available.
D-Link Quick Router Setup (QRS)
Initial setup and configuration can be accomplished using D-Link's Quick Router Setup (QRS) which allows customers to quickly configure their router using the QRS Mobile app for iOS or Android devices; no computer is necessary. Owners need simply plug in the D-Link DIR-865L router, open the app, and follow a few easy steps to establish their wireless network in minutes.
Standard Warranty: 1-Year
chevron icon
Product Description D-Link DIR-865L - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band 2.4 GHz / 5 GHz
Network / Transport Protocol PPTP, L2TP, IPSec
Features NAT support, Stateful Packet Inspection (SPI), manageable, IPv6 support, VPN passthrough, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), Green Ethernet
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac (draft 2.0)
Power AC 100/230 V (50/60 Hz)
Dimensions (WxDxH) 3.2 cm x 16.7 cm x 24 cm
Weight 0.55 kg
Microsoft Certification Compatible with Windows 7
System Requirements Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows XP SP3
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
