The DCS-2132L HD Wireless N Cube Cloud Camera is a mydlink-enabled IP surveillance camera that lets you monitor an area 24 hours a day. It helps you keep an eye on your home or office, even when you're away.
24/7 HD Surveillance for Your Home or Office
The DCS-2132L is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, highresolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera's video so you can survey a large area easily.
An infrared cut removable (ICR) filter is also built into the DCS-2132L, which blocks infrared light during the day for improved image quality. At night, it moves out of the way to use all available light for low-light surveillance, and paired with the IR LED illuminator, this camera can monitor an area even in complete darkness.
Anywhere Access with mydlink
The HD Wireless N Cube Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera's live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your iOS or Android mobile device. Keep an eye on your home while you're at work, or check on the office when you're out on the road; mydlink makes it all possible.
Zero Configuration
If you have a mydlink-enabled Cloud Router, setting up and configuring your DCS-2132L is a snap, thanks to mydlink Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable - the camera will automatically be added to your account. mydlink does the hard work for you, allowing users to set up and use their Cloud-enabled cameras immediately.
Built for Versatility
The DCS-2132L comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways or for caretaker applications. It even includes 802.11n wireless connectivity, allowing it to be placed anywhere easily without requiring cabling to be installed.
A Complete, Expandable Surveillance Solution
The DCS-2132L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities
Product Description | D-Link DCS-2132L HD Wireless N Cube Network Camera - network surveillance camera | Device Type | Network surveillance camera - fixed | Audio | Yes: built-in speaker, built-in microphone | Weight | 116 g | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Max Resolution | 1280 x 800 | Motion Detection | Yes | Optical Sensor Type | CMOS - 1/4" | Minimum Illumination | 0 lux - IR - F2.0 | Focal Length | 3.45 mm | Lens Iris | F/2.0 | Interfaces | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Voltage | DC 5 V | Features | Date/time stamp, sharpness control, saturation control, brightness control, contrast control, ONVIF support, microSD card slot, infrared cut filter, Privacy Mask Function, PIR-based motion detector, ePTZ | Environmental Parameters (operating) | 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, built-in microphone |
Weight | 116 g |
Localisation | United Kingdom |
Camera | |
Type | Colour - Day&Night - fixed |
Digital Video Format | MPEG-4, MJPEG, H.264 |
Max Digital Video Resolution | 1280 x 800 |
Digital Zoom | 10 |
Infrared LEDs | Yes |
Video Capture | 1280 x 800 , 1280 x 720 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 320 x 176 @ 30 fps , 176 x 144 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 480 x 360 @ 30 fps , 320 x 240 @ 30 fps |
Supported Image Formats | JPEG |
Image Sensor | |
Type | CMOS 1/4" |
Lens Construction | |
Lens Iris | F/2.0 |
Horizontal Field of View (degree) | 57.8 |
Vertical Field of View (degree) | 37.8 |
Interfaces | |
Network Interface | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Network Protocols | DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS |
Expansion / Connectivity | |
Interfaces | 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 |
Miscellaneous | |
Included Accessories | Stand |
Compliant Standards | C-Tick, FCC |
Power | |
Power Requirements | DC 5 V |
Power Device | Power adapter - external AC 120/230 V (50/60 Hz) 3.65 Watt |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Relative Humidity (operating) | 20 - 80% (non-condensing) |
