ITEM | QTY | PRICE |
OtterBox Symmetry Clear Apple iPad 8t...
3 | £92.28 |
LG 50" UR7800 4K Ultra HD Smart TV
3 | £897.00 |
How much content can you hold with your fingertips? With the Crucial X6 Portable SSD, the answer is: A lot! Whether you're downloading videos for off-line travel, organizing family photos, collaborating with classmates, or heading off on a great adventure, the Crucial X6 features [1TB/2TB] of portable storage capacity1 and is ready to go wherever you do.
Product Description | Crucial X6 - SSD - 1 TB - USB 3.1 Gen 2 | Type | Solid state drive - external (portable) | Capacity | 1 TB | Interface | USB 3.1 Gen 2 - USB-C | Data Transfer Rate | 10.0 Gbps (USB 3.1 Gen 2) | Features | Shock resistant | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 69 mm x 11 mm x 64 mm | Weight | 42 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 1 TB |
Interface | USB 3.1 Gen 2 |
Width | 69 mm |
Depth | 11 mm |
Height | 64 mm |
Weight | 42 g |
Performance | |
Interface Transfer Rate | 10.0 Gbps (USB 3.1 Gen 2) |
Internal Data Rate | 540 MBps |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 Gen 2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows, Android |
Miscellaneous | |
Cables Included | 1 x USB-C 3.2 Gen 2 cable - external |
Compliant Standards | UL, BSMI, RoHS, KCC, WEEE, RCM |
Package Type | Retail |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
Shock Tolerance (operating) | 3.1 g |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms |
Vibration Tolerance (operating) | 5-800 Hz |
