More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory-dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology.
Product Description | Crucial - DDR4 - kit - 64 GB: 4 x 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered | Product Type | Memory kit | Capacity | 64 GB: 4 x 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL17 | Features | Quad channel, unbuffered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Voltage | 1.2 V |
Miscellaneous | |
Colour Category | Green |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
