Crucial Apple Equivalent 4GB PC3-8500 DDR3 SODIMM
Engineered to be compatible with your Apple® system, Crucial® Memory for Mac takes the guesswork out of a memory upgrade. Since Apple systems often have very specific memory requirements, including particular component densities, speeds, and SPD programming specifications, it's important to buy your memory from people who know Apple computers inside and out. With over a decade of experience manufacturing and developing memory for Apple systems, Crucial make it easy to find memory that's been designed specifically for your system.
Reliability for Mac systems
If you're an Apple computer user, you probably expect intuitive, reliable performance from your system. Crucial think memory should work the same way, too. For each module Crucial manufacture, they send it through a rigorous testing process to ensure that you're getting a reliable, high-performance memory solution. Every module that leaves Crucial doors has been extensively tested at the component level for voltage and temperature resistances, signal integrity, and software compatibility. Even better, Crucial modules are lead and halogen-free*. The result? Reliable memory that meets or exceeds Apple's own memory requirements. * DDR3 modules only
Support for Mac systems
Unsure how to install memory or have an important question about your Apple system? Let Crucial's team of experts help! With a tech-savvy team that's well-versed in Apple systems, Crucial will provide the technical support you need - no matter how old your Mac computer gets. From phone support, videos, FAQ articles, and do-it-yourself guides, Crucial have got the resources you need to keep your system up to speed.
Crucial - quality you can depend on
Crucial is a trusted name when it comes to DRAM, and that's no coincidence. As a brand of Micron, one of the largest manufacturers of DRAM in the world, Crucial work with their engineers to design, refine, test, manufacture, and support their extensive line of memory modules. With a product portfolio that includes more than 250,000 different DRAM upgrades for more than 50,000 systems, Crucial have got one specifically designed for your Mac system. For more than a decade Crucial have kept Mac computer owners happy with high-performance memory and outstanding customer service. No matter what type of Mac system you have, Crucial have got a compatible solution.
Product Description | Crucial - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered | Product Type | Memory module | Capacity | 4 GB | Memory Type | DDR3 SDRAM - SO-DIMM 204-pin | Upgrade Type | System specific | Data Integrity Check | Non-ECC | Speed | 1066 MHz (PC3-8500) | Latency Timings | CL7 | Features | Unbuffered | Voltage | 1.5 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Capacity | 4 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR3 SDRAM |
Form Factor | SO-DIMM 204-pin |
Voltage | 1.5 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
