Marketing description is not available.
Product Description | Crucial - DDR4 - module - 32 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered | Product Type | Memory module | Capacity | 32 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin very low profile | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL17 | Features | Dual rank, registered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Capacity | 32 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin very low profile |
Module Configuration | 4096 x 72 |
Chips Organization | 4096 x 4 |
Voltage | 1.2 V |
Miscellaneous | |
Colour Category | Green |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
