Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Product Description | CORSAIR Vengeance LPX - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered | Product Type | Memory kit | Capacity | 32 GB: 2 x 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 2666 MHz (PC4-21300) | Latency Timings | CL16 (16-18-18-35) | Features | Dual channel, 8 Layers PCB heatspreader, Black PCB, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Voltage | 1.2 V |
RAM Performance | SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 2666 MHz - 1.2 V - CL16 - 16-18-18-35 |
Miscellaneous | |
Colour Category | White |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
