Corsair Vengance Pro Blue 8GB Kit (2X4GB) DDR3 1866MHz 1.5V
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
chevron icon
chevron icon
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
chevron icon
Product Description CORSAIR Vengeance Pro Series - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered
Product Type Memory kit
Capacity 8 GB: 2 x 4 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1866 MHz (PC3-15000)
Latency Timings CL9 (9-10-9-27)
Features Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), unbuffered
Voltage 1.5 V
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
