HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
Product Description | CORSAIR HXi Series HX1200i - power supply - 1200 Watt | Device Type | Power supply - internal | Specification Compliance | ATX12V 2.4/ EPS12V 2.92 | 80 PLUS Certification | 80 PLUS Platinum | Weight | 3.592 kg | Localisation | United Kingdom | Input Voltage | AC 100-240 V | Output Voltage | +3.3, +5, ±12 V | Power Capacity | 1200 Watt | Output Current | +3.3V - 30 A , +5V - 30 A , +12V - 100 A , -12V - 0.8 A , +5VSB - 3.5 A | Output connectors | 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector | Modular Cable Management | Yes | Cooling System | 140 mm fan | Dimensions (WxDxH) | 15 cm x 20 cm x 8.6 cm | Manufacturer Warranty | 10 years warranty |
General | |
PSU Form Factor | ATX |
Power Device | |
Frequency Required | 47 - 63 Hz |
Power Output Connectors Details | 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector |
Efficiency | 92% |
Miscellaneous | |
Cables Included | Power cable kit |
Features | Corsair Link, fan speed monitoring, over current protection, over voltage protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fluid dynamic bearing cooling fan, fully modular |
Compliant Standards | CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM |
Manufacturer Warranty | |
Service & Support | Limited warranty - 10 years |
Environmental Parameters | |
Max Operating Temperature | 50 °C |
Dimensions & Weight | |
Width | 15 cm |
Depth | 20 cm |
Height | 8.6 cm |
Weight | 3.592 kg |
