CORSAIR HX series power supplies give you extremely tight voltage regulation, quiet operation, Platinum-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential.
Product Description | CORSAIR HX Series HX750 - power supply - 750 Watt | Device Type | Power supply - internal | Specification Compliance | ATX12V 2.4/ EPS12V 2.92 | 80 PLUS Certification | 80 PLUS Platinum | Weight | 1.92 kg | Localisation | United Kingdom | Input Voltage | AC 100-240 V | Output Voltage | +3.3, +5, ±12 V | Power Capacity | 750 Watt | Output Current | +3.3V - 25 A , +5V - 25 A , +12V - 62.5 A , -12V - 0.8 A , +5VSB - 3 A | Output connectors | 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector | Modular Cable Management | Yes | Cooling System | 135 mm fan | Included Accessories | Case badge, cable ties, mounting kit | Dimensions (WxDxH) | 15 cm x 18 cm x 8.6 cm | Manufacturer Warranty | 10 years warranty |
General | |
PSU Form Factor | ATX |
Power Device | |
Frequency Required | 47 - 63 Hz |
Power Output Connectors Details | 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector |
Miscellaneous | |
Cables Included | Power cable kit |
Features | Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, fluid dynamic bearing cooling fan, switchable single/multi 12V rails, temperature sensor, fully modular |
Compliant Standards | CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 10 years |
Dimensions & Weight | |
Width | 15 cm |
Depth | 18 cm |
Height | 8.6 cm |
Weight | 1.92 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.4 cm |
Shipping Depth | 33.8 cm |
Shipping Height | 13.4 cm |
Shipping Weight | 3.77 kg |
