CMSO4GX3M1A1333C9 is Corsair's mainstream SODIMM memory solution for DDR3 laptops. Designed for notebooks, mini-PCs and netbooks, Corsair's high density SODIMMs allow users to maximize memory bandwidth and minimize performance bottleneck to deliver superior user experience.
Product Description | CORSAIR - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered | Product Type | Memory module | Capacity | 4 GB | Memory Type | DDR3 SDRAM - SO-DIMM 204-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1333 MHz (PC3-10600) | Latency Timings | CL9 (9-9-9-24) | Features | Unbuffered | Voltage | 1.5 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Capacity | 4 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR3 SDRAM |
Form Factor | SO-DIMM 204-pin |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - SO-DIMM 204-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
