Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Product Description | CORSAIR Vengeance Pro Series - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered | Product Type | Memory kit | Capacity | 16 GB: 2 x 8 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1600 MHz (PC3-12800) | Latency Timings | CL9 (9-9-9-24) | Features | Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), unbuffered | Voltage | 1.5 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 2 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
