CoolerMaster B500 Power Supply Unit
Key features
  • Higher than 85% efficiency under typical operation
  • Silent 120 mm HDB fan with intelligent fan-speed control
  • Green power design
  • Powerful +12 V rail for strong resistance to any overloading
  • Multiple built-in protection systems
Product codes
chevron icon
chevron icon
The very successful B-series has been revised. A complete circuit layout and components make it compliant to the regulations. The biggest difference for the B-series is that it only has a single rail +12 V DC out with a max current of 38 A. This now means that all Cooler Master power supplies makes use of a single rail instead of multi rail.
chevron icon
Product Description Cooler Master B500 ver.2 - power supply - 500 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.31
Localisation United Kingdom
Input Voltage AC 230 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 500 Watt
Output Current +3.3V - 20 A , +5V - 20 A , +12V - 38 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System 120 mm fan
Dimensions (WxDxH) 15 cm x 14 cm x 8.6 cm
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
