Waterproof and shockproof, the durable PowerShot D10 brings quality 12.1 MP imaging to active outdoor activities. Keep your hands free and your camera close with a range of great accessories
For those with a taste for adventure, there's a camera as bold as the active life you lead. It's the Canon PowerShot D10. Waterproof, freezeproof and shockproof; it's tough enough to take what you dish out. Plus it's got all the high performance features you expect from a Canon digital camera. You've got 12.1-megapixel of resolution plus all of Canon's powerful, state-of-the-art imaging technologies so you can capture your epic experiences in breathtaking color and awesome detail.
Shoot almost anywhere
The PowerShot D10 is ideal for a wide range of outdoor activities, from climbing to snorkelling. It offers water resistance to 10m, shock resistance for unexpected knocks or drops, operates in temperatures as low as -10 °C, and is fully protected from dust.
12.1 MP
A 12.1 Megapixel resolution gives you the freedom to crop or enlarge images, while retaining outstanding image detail.
3.0x zoom and optical IS
Canon's 3.0x optical zoom lens features an optical Image Stabilizer, to guard images against blur caused by camera shake - essential in active, high-movement activities.
Incredible images more easily
Smart Auto mode uses intelligent Scene Detection Technology to determine subject brightness, contrast, distance and overall hue. The camera then searches an incredible 18 possible modes, and selects the one which offers the perfect settings for the scene - giving you great results from simple point-and-shoot operation.
DIGIC 4
Canon's DIGIC 4 processor drives responsive operation, superb image quality and colour reproduction. Advanced Noise Reduction ensures richly detailed, cleaner images, even at high ISO speeds.
Extra-bright LCD
For easy framing and image review in any environment, a 2.5" PureColor LCD II offers twice the normal levels of brightness. A 2mm Perspex shield protects the screen against scuffs and fingerprints.
No more blur
Motion Detection Technology uses a range of advanced methods to ascertain movement of both camera and subject, plus the speed at which this motion occurs. The optimum ISO is then automatically set for any situation.
Face Detection Technology
A suite of Face Detection technologies detect up to 35 faces in a shot, adjusting key settings for optimal results with natural-looking skin tones. Blink Detection lets you avoid mistimed people shots, while FaceSelf-Timer takes a shot when an extra face is detected in the frame - making group photos easy.
Active accessories
Two optional strap sets - one for Shoulder & Neck, one with a Carabiner Strap - keep your hands free and your camera within easy reach. You can also customise the PowerShot D10 with a colourful front cover set.
Range of shooting modes
A wide range of shooting modes and Special Scene modes - including Underwater, Snow and Beach modes - delivers instant access to the right settings for any environment.
Movie mode
Supplement images with fun VGA movie clips.
Product Description | Canon PowerShot D10 - digital camera | Product Type | Digital camera - compact | Memory Card Slot | SD card | Image Processor | DIGIC 4 | Sensor Resolution | 12.1 Megapixel | Lens System | Zoom lens - 3x zoom - 6.2 - 18.6 mm - f/2.8-4.9 | Focus Adjustment | Automatic, manual | Min Focus Distance | 30 cm | Digital Zoom | 4x | Image Stabiliser | Optical | Camera Flash | Built-in flash | Display | LCD display - 2.5" | Supported Battery | Canon NB-6L Li-ion rechargeable battery (included) | Interface | Composite video/audio, USB 2.0 | Dimensions (WxDxH) | 10.4 cm x 4.9 cm x 6.7 cm | Weight | 190 g |
General | |
Optical Sensor Type | CCD |
Total Pixels | 12,700,000 pixels |
Effective Sensor Resolution | 12,100,000 pixels |
Optical Sensor Size | 1/2.3" |
ISO (Max) | 3200 |
Optical Zoom | 3x |
Digital Zoom | 4x |
Built-in Optical Image Stabiliser | Yes |
Face Detection | Yes |
Print Standard | Direct print, DPOF support, Exif Print support, PictBridge support |
Auto Focus | TTL contrast detection |
Auto Focus Points (Zones) Qty | 9 |
Face Detection | Blink Detection technology, Face Detection AF/AE/FE/WB, Face Detection Self-timer |
Digital Video Format | H.264 |
Image Recording Format | JPEG |
Exposure & White Balance | |
Light Sensitivity | ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto |
Exposure Metering | Evaluative, centre-weighted, spot |
Exposure Modes | Programme, automatic |
Shooting Programs | Landscape, portrait mode, slow shutter, stitch assist, fireworks, Underwater, sunset, indoor, foliage, beach, kids & pets, night snapshot, snow, high sensitivity, Colour Swap, Colour Accent, aquarium |
Special Effects | Black & White, Sepia, Neutral, Vivid, Custom Effect, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, Positive Film |
White Balance | Custom, automatic, presets |
White Balance Presets | Cloudy, tungsten light, daylight, fluorescent light (cool white), fluorescent light (warm white), Underwater |
Max Shutter Speed | 1/1500 sec |
Min Shutter Speed | 15 sec |
Exposure Compensation | ±2 EV range, in 1/3 EV steps |
Lens System | |
Type | Zoom lens - 3x zoom - 6.2 - 18.6 mm - f/2.8-4.9 |
Focal Length Equivalent to 35mm Camera | 35 - 105mm |
Macro Focus Range | 3-50cm |
Zoom Adjustment | Motorised drive |
Lens Construction | 5 groups / 6 elements |
Features | Aspherical lens, UA lens |
Camera Flash | |
Flash Modes | Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction |
Red-Eye Reduction | Yes |
Features | AF illuminator |
Effective Flash Range | 0.3 m - 3.2 m |
Additional Features | |
Continuous Shooting Speed | 1.1 frames per second |
Self-Timer Delay | 10 sec, 2sec |
Additional Features | RGB primary colour filter, digital noise reduction, digital image rotation, camera orientation detection, histogram display, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, Scene Detection Technology, in-camera red-eye fix, digital tele-converter, safety zoom, Motion Detection Technology |
Display | |
Type | 2.5" LCD display |
Display Format | 230,000 pixels |
Display Form Factor | Built-in |
Display Features | Display brightness control |
Microphone | |
Microphone Operation Mode | Mono |
Connections | |
Connector Type | USB , Composite video/audio output |
Software | |
Software | Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser |
Miscellaneous | |
Included Accessories | Battery charger, USB cable, wrist strap, audio / video cable |
Protection | Waterproof, freezeproof, shockproof, dust-resistant |
Underwater Use | Yes |
Underwater Depth | Up to 10 m |
Battery | |
Battery Type | Canon NB-6L Lithium Ion |
Details | Canon NB-6L Li-ion rechargeable battery (included) |
Memory / Storage | |
Supported Memory Cards | MultiMediaCard, SD Memory Card, SDHC Memory Card, MultiMediaCardplus |
Image Storage | JPEG 4000 x 3000 , JPEG 3264 x 2448 , JPEG 2592 x 1944 , JPEG 1600 x 1200 , JPEG 640 x 480 , JPEG 4000 x 2248 |
Video Capture | H.264 - 640 x 480 - 30 fps , H.264 - 320 x 240 - 30 fps |
Dimensions & Weight | |
Width | 10.4 cm |
Depth | 4.9 cm |
Height | 6.7 cm |
Weight | 190 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
