Wi-Fi scanner for wireless connectivity in the office, point-of-sale or in the home.
Wi-Fi scanner for wireless connectivity in the office, point-of-sale or in the home. The DR-C225W's built-in Wi-Fi allows wireless scanning from mobile, tablet and PC devices. Ideal for sharing among office users, capturing documents at customer retail points and scanning in the home.
Main Features
Flexible capture and sharing
The DR-C225W with built-in Wi-Fi delivers a better customer experience and faster decision making. It enables iPads®, iPhones® and Android devices to efficiently batch-capture documents directly at the point-of-sale. Important customer data can quickly be validated and immediately sent into cloud-based business workflows and information management systems for faster processing. Businesses can share the DR-C225W wirelessly among corporate departments or small offices. The easy-to-use Wireless Connection Setup tool enables a smoother switching between Access Point Mode and Station Mode (Infrastructure mode). The DR-C225W can also operate using a standard USB connection.
Compact profile, inspired design
Thanks to its unique vertical J-Path document feeding design, the DR-C225W uses less desk space when scanning. The scanner can be conveniently positioned on a small narrow desk, a window-shelf or at customer retail points where space may be restricted.
Fast, versatile scanning
To help teams work quickly and efficiently, the DR-C225W offers high speed, double sided scanning of up to 50ipm in Wi-Fi mode.¹ The 30-sheet automatic document feeder, incorporating ultrasonic double-feed detection, reliably processes a batch of mixed documents. The selectable straight feeding path enables easy scanning of ID cards, photos and 3m long paper.
Advanced image processing
The DR-C225W includes advanced image processing features, including auto colour detection, text enhancement and deskew. MultiStream™ technology allows simultaneous image outputs in different scanning modes.
CaptureOnTouch
Get a simpler and more intuitive scanning experience with the CaptureOnTouch software’s step-by-step, icon-based user interface. Newly enhanced features put a range of powerful yet easy-to-use document scanning and editing capabilities at your fingertips. In Full Auto Mode, CaptureOnTouch automatically applies the ideal scanning settings for the document content.
Software to streamline tasks
The DR-C225W comes with a powerful range of ‘out of the box’ software to increase productivity when working on your desktop PC, including: BizCard, PaperPort (Win), OmniPage, eCopy PDF Pro Office and PageManager (Mac). You can also increase productivity with additional plugins for SharePoint, Evernote, SugarSync, OneDrive, Google Drive™ and Dropbox.
Product Description | Canon imageFORMULA DR-C225W - document scanner - desktop - USB 2.0, Wi-Fi(n) | Device Type | Document scanner - desktop | Interface Type | USB 2.0, Wi-Fi(n) | Scanning Sensor Type | CMOS / CIS | Light Source | RGB LED array | Max Supported Document Size | 216 x 3000 mm | Input Type | Colour | Grayscale / Color Depth | 8-bit (256 grey levels) / 24-bit (16.7 million colours) | Optical Resolution | 600 dpi x 600 dpi | Max Document Scan Speed | 25 ppm (mono) / 25 ppm (colour) | Max Document Size | 216 mm x 3000 mm | Automatic Duplexing | Yes | Supported Document Type | Plain paper, business card, plastic card | Document Feeder Type | Automatic | Document Storage Capacity | 30 sheets | Duty Cycle | 1500 scans per day | Power | AC 120/230 V (50/60 Hz) | System Requirements | Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Android, Windows 8, Apple iOS | Dimensions (WxDxH) | 30 cm x 15.6 cm x 22 cm | Weight | 2.8 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Scanner | |
Grayscale Depth | 8-bit (256 grey levels) |
Colour Depth | 24-bit (16.7 million colours) |
Bulb / Light Source Type | RGB LED array |
Max Document Scan Speed B/W | 25 ppm |
Max Document Scan Speed Colour | 25 ppm |
Scanner Speed Details | 25 ppm - black & white , 50 ipm - duplex - black & white , 25 ppm - colour , 50 ipm - duplex - colour |
Scanner Features | Color Dropout, Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Text Orientation Recognition, automatic resolution setting, Smooth Background, Punch Hole Removal, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Character Emphasis, Shadow Cropping, Deskew, Shading Correction, Contrast Arrangment, Color Drift, Edge Enhancement, Red Color Enhancement, Erase Shadow |
Compliant Standards | TWAIN, ISIS |
Media Handling | |
Expansion / Connectivity | |
Interfaces Details | USB 2.0 - Type B |
Miscellaneous | |
Compliant Standards | RoHS |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 12.8 Watt (1.9 Watt) |
Software / System Requirements | |
Software Included | Drivers & Utilities, Presto! BizCard Reader, Canon CaptureOnTouch, Nuance PaperPort, Nuance OmniPage, Nuance eCopy PDF Pro Office, Presto! PageManager for Mac, Canon CaptureOnTouch for Mac, Presto! BizCard Reader for Mac |
OS Required | Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Android, Windows 8, Apple iOS |
Dimensions & Weight | |
Width | 30 cm |
Depth | 15.6 cm |
Height | 22 cm |
Weight | 2.8 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 20 - 80% |
