Canon EOS 1100D Kit - with 18-55mm Lens, Tripod, SLR Bag & 8GB SD Card
EVERYTHING YOU NEED TO GET STARTED IN SLR!
Key features
  • Superior 12-megapixel image quality
  • On-screen feature guide
  • Creative Auto and Basic+
  • HD video capture
  • ISO 100-6400 sensitivity
  • Wide-area 9-point AF system
Product codes
chevron icon
chevron icon
Canon EOS 1100D - Take the first step
Advanced, compact and affordable: your first steps into the world of DSLR photography, made simple with Canon EOS 1100D.
- Superior 12-megapixel image quality
- On-screen Feature Guide
- Creative Auto and Basic+
- HD video capture
- ISO 100-6400 sensitivity
- Wide-area 9-point AF system
- 63-zone iFCL exposure metering
- 6.8cm (2.7"), 230,000-dot screen
- Use with all EF and EF-S lenses
12-megapixel resolution
Step up to DSLR image quality with a 12-megapixel APS-C-sized sensor. A 14-bit DIGIC 4 image processor provides up to 3.2fps continuous shooting and images that are packed with detail and tonal range.
Intuitive, on-screen feature guide
The EOS 1100D's Feature Guide provides descriptions of many of the camera's functions, as well as advice on how to use them in your own photography.
Easy to use Scene modes and Basic+
Theme-based Scene modes automatically pick the most suitable exposure, focus and drive-mode settings for the subject being photographed, while Creative Auto mode portrays adjustable functions in an easy to understand way. With Canon's Basic + technology, the look and feel of these basic auto modes can be fine-tuned according to ambience and lighting type.
HD EOS Movie mode
Shoot stunning HD video at 25 or 30fps, with automatic exposure control leaving you free to concentrate on the action. Footage can be edited on your PC or Mac, or played directly on an HD TV via the camera's HDMI connection.
Low-light shooting without flash is possible thanks to the EOS 1100D's ISO 100-6400 sensitivity range. The camera's 14-bit DIGIC 4 processor helps to control noise and maintain image quality.
The EOS 1100D focuses quickly and accurately on static and moving subjects, thanks to nine AF points, spread out across the frame. A central cross-type AF point is sensitive to both horizontal and vertical lines.
Advanced iFCL exposure metering dissects a scene into 63-zones before analyzing it to find the perfect combination of shutter speed, aperture and ISO.
6.8cm (2.7"), 230,000-dot LCD screen
Compose and review images on a large 230,000-dot LCD screen, which also provides access to the camera's menu system and Quick Control Screen.
The EOS 1100D is supported by the complete range of EOS lenses and accessories: flashguns, remote releases and a system of more than 60 lenses trusted by professional photographers the world over.
chevron icon
Product Description Canon EOS 1100D - digital camera EF-S 18-55mm DC III lens
Product Type Digital camera - 720p - SLR with Live View mode, movie recording
Lens Included EF-S 18-55mm DC III lens
Memory Card Slot SD card
Image Processor DIGIC 4
Sensor Resolution 12.0 Megapixel
Max Video Resolution 1280 x 720
Lens System Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 III Canon EF-S
Focus Adjustment Automatic, manual
Camera Flash Pop-up flash
Viewfinder Optical - eye-level mirror pentaprism
Display LCD display - 2.7"
Supported Battery Li-ion rechargeable battery (included)
Interface Composite video/audio, HDMI, USB 2.0
Microsoft Certification Compatible with Windows 7
Colour Black
Dimensions (WxDxH) 13 cm x 7.8 cm x 10 cm
Weight 495 g
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
