The LV-7390 combines the performance of 3000 lumens, XGA resolution with networking capability. Easy, eco-friendly operation and up to 6000 hour lamp life is ideal for more challenging environments.
The LV-7390, 3000 lumens XGA projector is ideal for more demanding environments.
Bright, bold presentations
In more exacting environments that demand bright and detailed image projection, the LV-7390 is a natural fit. Featuring native XGA resolution (1024×768), 3000 lumens and a 2000:1 contrast ratio with Auto Iris, the LV-7390 gives consistent deep blacks and powerful colours throughout the spectrum - even in brightly lit rooms or in high levels of ambient light.
Premium lens technology
The LV-7390 features a high quality wide-angle 1.2x zoom projection lens that leverages Canon's 70 year heritage as a world class lens manufacturer. Although able to project clear and undistorted images in confined spaces, the LV-7390 delivers high quality images throughout its entire throw distance range.
The flexibility for demanding environments
Wherever or however you need the LV-7390 to perform, you'll find its convenient features help you get results with no fuss. It's the ideal device for mobile teams: Auto Input Search and Auto Vertical Keystone Correction of ± 20° make the LV-7390 quick and convenient to set up, while just 29dBA in Eco Mode means your audience won't be distracted by the projector's fan noise - even in intimate spaces. Weighing just 2.9kg, the LV-7390 is highly portable with powerful features.
Get connected
An RJ-45 network port lets you monitor and control the LV-7390 remotely - ideal for plug-and-play integration with room control systems or connection to the corporate LAN. A built-in 10W speaker and line-out terminal give you a choice of flexible audio options.
Sustaining our environment
Reflecting Canon's philosophy as a `green' business, the LV-7390 includes a range of energy and resource saving features. A 6000 hour lamp life, 5500 hour filter life and less than 1W power consumption in standby (with network off) all contribute to cost reduction.
Lower cost, lower maintenance
The LV-7390 doesn't just carry a competitive upfront price tag: it also includes many long-life and user-serviceable parts, for example a three-layer hybrid air filter that keeps your total cost of ownership reassuringly low. These last over three and a half times longer than standard one-layer electrostatic versions, while easy lamp changes via the projector's top cover reduce your reliance on expensive external support.
Product Description | Canon LV-7390 - LCD projector - portable | Device Type | LCD projector | Built-in Devices | Speaker | Brightness | 3000 lumens | Contrast Ratio | 2000:1 | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Bulb type | NSHA 215 Watt | Bulb life cycle | Up to 6000 hour(s) - economic mode | Video Input | RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43) | Video Modes | 480p, 720p, 1080i, 480i, 1035i, 576i, 576p | Video Output | RGB | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 33.4 cm x 24.7 cm x 10.1 cm | Weight | 2.9 kg | Manufacturer Warranty | 3-year warranty |
General | |
Projector | |
Image Size | 102 cm - 762 cm |
Projection Distance | 1.1 m - 10.5 m |
Uniformity | 85 % |
Digital Zoom Factor | 4x |
Resolution | XGA - XGA (1024 x 768) |
Display Format | 786,432 pixels |
Controls & Adjustments | Keystone correction |
Lens | |
Focus Type | Manual |
Lens Aperture | F/2.0-2.15 |
Zoom Type | Manual |
Zoom Factor | 1.2x |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -30 / +30 |
Video Input | |
TV System | NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43 |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, composite video |
Video Output | |
Analogue Video Signal | RGB |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 10 Watt |
Speakers | 1 x mixed channel |
Input Device | |
Type | External |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB / S-video - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) |
Miscellaneous | |
Included Accessories | Lens cover, wireless remote control |
Security Features | PIN code |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 0.7 Watt |
Dimensions & Weight | |
Width | 33.4 cm |
Depth | 24.7 cm |
Height | 10.1 cm |
Weight | 2.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Sound Emission | 34.4 dB |
Sound Emission (Economic Mode) | 29 dB |
