ITEM | QTY | PRICE |
StarTech.com 1.5 m CAT6a Cable - Blue...
3 | £36.18 |
HP Officejet Pro 9010e AllinOne Multi...
3 | £657.00 |
Asus VivoBook 15 Intel Core i5-1235U...
1 | £449.98 |
The DVI-D male to HDMI female Inline Adapter provides a pure digital, high definition video connection, allowing you can connect your digital source device to a DVI-equipped display device with absolutely no reduction in picture quality. This Adapter supports up to a 1080p resolution and is compatible with satellite, DVD player, HDTV, Plasma, LCD and DLP applications. Additionally, gold-plated contacts deliver worry-free performance.
Product Description | C2G Velocity Inline Adapter - adapter - HDMI / DVI | Cable | Adapter - HDMI / DVI | Colour | Black | Connector | DVI-D - male | Connector (Second End) | HDMI - female | Features | Thumbscrews | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter |
Interface Supported | HDMI / DVI |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 18+1 pin digital DVI (Single-Link) - male |
Connector (Second End) | 19 pin HDMI Type A - female |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
