The DVI-D female to HDMI male Inline Adapter provides a pure digital, high definition video connection, allowing you can connect your digital source device to a HDMI-equipped display device with absolutely no reduction in picture quality. This Adapter supports up to a 1080p resolution and is compatible with satellite, DVD player, HDTV, Plasma, LCD and DLP applications. Additionally, gold-plated contacts deliver worry-free performance.
Product Description | C2G Velocity Inline Adapter - adapter - HDMI / DVI | Cable | Adapter - HDMI / DVI | Colour | Black | Connector | DVI-D - female | Connector (Second End) | HDMI - male | Manufacturer Warranty | 1-year warranty |
General | |
Cable Type | Adapter |
Interface Supported | HDMI / DVI |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 24+1 pin digital DVI - female |
Connector (Second End) | 19 pin HDMI Type A - male |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
