With its 480 Mbps of available bandwidth, you get true 10/100 network access. The plug-and-play design makes this adapter the most convenient and efficient way to connect a laptop or desktop computer to a fast ethernet network. With our fast ethernet adapter, you can experience the full speed of your fast ethernet network without the need for opening your PC and adding internal network adapters.
Our adapter allows you to share the internet or printers, transfer files, compete in multiplayer games and more at speeds up to 200 Mbps (in full duplex mode). The portable, compact size makes it ideal for use with laptops. Hot-swappable and 100% compatible with both USB 2.0 and 1.1 hardware.
Product Description | C2G USB 2.0 To Fast Ethernet Adapter - network adapter - USB 2.0 - 10/100 Ethernet | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Ports | 10/100 Ethernet | Weight | 101 g | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX | Data Link Protocol | 10Mb LAN, 100Mb LAN | Data Transfer Rate | 100 Mbps | System Requirements | Apple MacOS X 10.3.x or later, Microsoft Windows Vista / 2000 / XP |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet |
Features | Half duplex mode, full duplex mode |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Connections | 1 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Cables Included | 1 x USB cable (integrated) - 19 cm |
Compliant Standards | Plug and Play, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Apple MacOS X 10.3.x or later, Microsoft Windows Vista / 2000 / XP |
Additional Requirements | CD-ROM |
Dimensions & Weight | |
Weight | 101 g |
