C2G USB 2.0 To Fast Ethernet Adapter
Key features
  • USB 2.0 for high speed connectivity
Product codes
chevron icon
chevron icon
With its 480 Mbps of available bandwidth, you get true 10/100 network access. The plug-and-play design makes this adapter the most convenient and efficient way to connect a laptop or desktop computer to a fast ethernet network. With our fast ethernet adapter, you can experience the full speed of your fast ethernet network without the need for opening your PC and adding internal network adapters.
Our adapter allows you to share the internet or printers, transfer files, compete in multiplayer games and more at speeds up to 200 Mbps (in full duplex mode). The portable, compact size makes it ideal for use with laptops. Hot-swappable and 100% compatible with both USB 2.0 and 1.1 hardware.
chevron icon
Product Description C2G USB 2.0 To Fast Ethernet Adapter - network adapter - USB 2.0 - 10/100 Ethernet
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports 10/100 Ethernet
Weight 101 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
System Requirements Apple MacOS X 10.3.x or later, Microsoft Windows Vista / 2000 / XP
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
