The DB9 port saver adapter from C2G will quickly and easily extend the life of equipment connectors. An inexpensive solution for eliminating the stress of plugging and unplugging cables, each port saver is molded and fully shielded, preventing any unwanted EMI/RFI interference caused from office equipment.
Product Description | C2G PORT SAVER ADAPTER - serial adapter - DB-9 to DB-9 | Type | Serial adapter | Technology | Shielded | Features | Molded | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 9 pin D-Sub (DB-9) - female |
General | |
Features | Molded |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
