ITEM | QTY | PRICE |
StarTech.com 4 Port USB 3.0 Hub 5Gbps...
3 | £78.33 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter allows the Mini DisplayPort video output of a laptop to connect to the HDMI input of a display and is perfect for applications including displaying video on an HDTV, projector, or monitor in a classroom, on a desktop, or in a meeting room. This Mini DisplayPort to HDMI active adapter can be used in either DisplayPort single-mode or dual-mode outputs , providing the conversion for a Mini DisplayPort source even when that source does not support DP++. Active Mini DisplayPort conversion is excellent for applications where multiple Mini DisplayPort adapters are required to connect to a single graphics card. This allows every active adapter to interface with a corresponding display. On The Go Enhanced.
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connection in an ultra-compact design. The Mini DisplayPort to HDMI adapter can connect a Mini DisplayPort equipped laptop or tablet to a projector, monitor, or HDTV with a HDMI input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments. Straightforward Install.
This simple plug and play adapter converter does not require drivers for install and the device is powered through Mini DisplayPort bus power, so no additional power adapters are needed. Port Protection.
The dongle-style adapter converter reduces strain on the video port. The cable between the Mini DisplayPort connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved. Note: When this device is connected to a Mini DisplayPort source device that supports audio and an DVI-D to HDMI Cable with the HDMI connector plugged into a HDMI display device that supports audio both audio and video signal will be transmitted from the source device to the display device. However connecting to a DVI-D display will not allow audio to pass to the display.
Product Description | C2G Mini DisplayPort to HDMI Active Adapter Converter 4K UHD - Black - adapter - DisplayPort / HDMI | Cable | Adapter - DisplayPort / HDMI | Technology | Triple shielded | Colour | Black | Connector | Mini DisplayPort - male | Connector (Second End) | HDMI - female | Features | 4K support | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Adapter 4K support |
Interface Supported | DisplayPort / HDMI |
Jacket Material | PVC |
Colour | Black |
Connectivity | |
Connector (Second End) | 19 pin HDMI Type A - female |
Dimensions & Weight | |
Weight | 89 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
