RCA Audio/Video cables from C2G are designed to attach the audio/video from your DVD, camcorder, computer or Hi-Fi VCR to your AV receiver. These low-cost cables are of higher quality than most standard video cables giving you crisp, clear sound and video for less. The connectors are color-coded for easy installation and identification and provide excellent strain relief.
Product Description | C2G Value Series video / audio cable - composite video / audio - 7 m | Cable | Video / audio cable - composite video / audio | Technology | Shielded | Length | 7 m | Colour | Black | Connector | 3 x RCA - male | Connector (Second End) | 3 x RCA - male | Features | Colour-coded connectors, moulded | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Video / audio cable |
Interface Supported | Composite video / audio |
Jacket Material | PVC |
Shielding Material | Copper braid |
Length | 7 m |
Plated Connector | Nickel |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
