ITEM | QTY | PRICE |
Nokia G11 32GB Dual Sim Android Smart...
4 | £479.92 |
Asus ExpertBook B1 Intel Core i5-1235...
1 | £572.47 |
Motorola E13 Creamy White
4 | £279.96 |
This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 19.8 metres total extension! Both low and high speed USB devices will function equally well with this extension.
Product Description | C2G USB Active Extension Cable - USB extension cable - USB to USB - 5 m | Type | USB extension cable | Features | Active cable (signal regeneration) | Length | 5 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type A - female | Compliant Standards | USB / USB 2.0 |
General | |
Length | 5 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, Plug and Play, RoHS |
