Ultima HDTV Video Cables from C2G are specifically designed for digital and next generation, high definition analog video applications. The Ultima HDTV Video Cables are constructed from three individually shielded, 75-Ohm coax cables, which provide a performance connection that maximizes color and image. The Ultima HDTV Video Cable meets the rigid standards of everyday use.
Product Description | C2G Ultima HDTV Component Video Breakout Cable - video cable - component video - 3 m | Cable | Video cable - component video | Technology | Shielded | Length | 3 m | Connector | HD-15 (VGA) - male | Connector (Second End) | 3 x RCA - male | Features | Moulded, thumbscrews | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Video cable |
Interface Supported | Component video |
Shielding Material | Foil with copper braid |
Impedance | 75 Ohm |
Length | 3 m |
Plated Connector | Gold |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
