C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue
Key features
  • Protect 10 Gigabit data transmissions from 10GBase-T ports and equipment in high noise environments.
  • Connector 1: (1) RJ-45 Male
  • Snagless booted design protects clips when plugging and unplugging
  • Connector 2: (1) RJ-45 Male
  • Standard shielded RJ45 connectors and shielded twisted pair wires
  • Lifetime warranty
Product codes
chevron icon
chevron icon
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
chevron icon
Product Description C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 30 m - blue
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Shielding Material Aluminium foil
Wires per Cable 8 wires
Features Molded, snagless, stranded
Length 30 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
