Velocity digital audio coax cables from C2G are perfect for carrying the digital audio stream from a CD transport, DVD player, DAT deck or other digital component to an A/V receiver digital input or the input of an outboard D/A converter.
Product Description | C2G Velocity digital audio cable (coaxial) - 2 m | Cable | Digital audio cable (coaxial) | Technology | Triple shielded coaxial | Length | 2 m | Connector | RCA - male | Connector (Second End) | RCA - male | Features | OFC (Oxygen Free Copper), moulded |
General | |
Cable Type | Digital audio cable (coaxial) |
Jacket Material | Ultra flexible PVC |
Shielding Material | Aluminium foil with copper braid |
Impedance | 75 Ohm |
Length | 2 m |
Plated Connector | Gold |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
