Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small right angle form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
Product Description | C2G USB 2.0 A Right Angle to Micro-USB B Right Angle Cable - USB cable - Micro-USB Type B to USB - 2 m | Type | USB cable | Features | 90° connector, right-angled connector, sync and charge, USB On-The-Go | Length | 2 m | Connector | 5 pin Micro-USB Type B - male | Connector (Second End) | 4 pin USB Type A - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | USB cable |
Length | 2 m |
Colour | Black |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
