This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed digital video transmission up to 9.9 Gbps. 28 AWG copper conductors are individually insulated in foam-polypropylene to minimize crosstalk, and ensure high-speed, error-free transmission.
Product Description | C2G DVI extension cable - 2 m | Type | DVI extension cable - dual link | Technology | Triple shielded | Features | Colour-coded connectors | Length | 2 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - female | Compliant Standards | PC 99, RoHS |
General | |
Type | DVI extension cable |
Shielding Material | Foil with braid |
American Wire Gauge (AWG) | 28 |
TMDS Links | Dual link |
Plated Connector | Gold |
Length | 2 m |
Connectivity | |
Connector | 24+1 pin digital DVI - male |
Connector (Second End) | 24+1 pin digital DVI - female |
Miscellaneous | |
