DVI analog extension cables from C2G deliver the high performance, high-bandwidth interface needed for video displays of today while leaving flexibility for the products of tomorrow. It is perfect for connecting a DVI-A connector to a monitor with a VGA cable. These precision-engineered cables are fully compliant with the DVI standard as defined by DDWG (Digital Display Working Group).
Product Description | C2G VGA extension cable - 2 m | Type | VGA extension cable | Technology | Triple shielded coaxial | Features | Colour-coded connectors | Length | 2 m | Connector | DVI-A - female | Connector (Second End) | HD-15 (VGA) - male | Compliant Standards | PC 99, RoHS |
General | |
Shielding Material | Foil with tinned copper braid |
American Wire Gauge (AWG) | 28/30 |
Plated Connector | Gold |
Length | 2 m |
Connectivity | |
Connector | 12+5 pin analogue DVI - female |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Miscellaneous | |
