We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description | C2G 2m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 2 m | Type | DisplayPort cable | Technology | Shielded | Length | 2 m | Connector | DisplayPort - male | Connector (Second End) | DVI-D - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Shielding Material | PVC |
American Wire Gauge (AWG) | 30 |
Length | 2 m |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 18+1 pin digital DVI (Single-Link) - male |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
