This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed transmission up to 9.9 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
Product Description | C2G DVI cable - 1 m | Type | DVI cable - dual link | Technology | Triple shielded | Features | Colour-coded connectors | Length | 1 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - male | Compliant Standards | PC 99, RoHS |
General | |
Type | DVI cable |
Shielding Material | Foil with braid |
American Wire Gauge (AWG) | 28 |
TMDS Links | Dual link |
Plated Connector | Gold |
Length | 1 m |
Connectivity | |
Connector | 24+1 pin digital DVI - male |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
