ITEM | QTY | PRICE |
Lenovo Tab P11 ZA7S 128GB 11" An...
4 | £1,173.84 |
Serial ATA cable by C2G is designed to handle the differential signals implemented in today's technology. The angled connectors deliver the cable at a more desired angle and are fortified to keep the cable lined up straight. Serial ATA cables minimize clutter, increase airflow and provide maximum transfer rates. The 7-pin, Serial ATA cables permit higher data transmission rates, reduce crosstalk and improve signal integrity.
Product Description | C2G 180 Degree to 90 Degree Right Angle Serial ATA (SATA) Cable - SATA cable - 1 m | Type | SATA cable | Interface Speed | Serial ATA 150/300/600 | Features | 90° connector, right-angled connector, 180° connector | Length | 1 m | Connector | 7 pin Serial ATA - female | Connector (Second End) | 7 pin Serial ATA - female | Colour | Red | Manufacturer Warranty | Limited lifetime warranty |
General | |
Storage Cable Type | SATA cable |
Length | 1 m |
Colour | Red |
Connectivity | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
