This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a Reduced Bit Rate (RBR) bandwidth means that this cable can carry up to a 1920x1080 resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Product Description | C2G 10m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 10 m | Type | DisplayPort cable | Features | Latched | Length | 10 m | Connector | DisplayPort - male | Connector (Second End) | DisplayPort - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 10 m |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 20 pin DisplayPort - male |
Miscellaneous | |
Compliant Standards | DisplayPort 1.2 |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
