We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
Product Description | C2G Extension Cable - serial extension cable - DB-9 to DB-9 - 10 m | Type | Serial extension cable | Technology | Shielded | Features | Molded, thumbscrews | Length | 10 m | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 9 pin D-Sub (DB-9) - female | Colour | Black |
General | |
Length | 10 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
