For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Product Description | C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - white | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded, snagless, stranded | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | White |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 10 m |
Colour | White |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 350 MHz |
